Originalmente Colocado por
GTTDI
No ESP, no Kopfairbags, miserable brakes and a quite simple chassis: The Agila no more is technical on the height of the time. Risky evasive maneuvers are not recommended.
www.autobild.de/artikel/peugeot-1007-_-opel-a...
Surprise! 2007 Toyota Hilux Fails the Moose Test
By Alex Dykes
October 31, 2007
You may remember Sweden's infamous
Älgtest (a.k.a. moose or Elk test). A kamikaze professional driver guides a fully-laden vehicle (simulated passengers, genuine cargo) down a closed course at 35.5mph. He/she then swerves to avoid an object, then swerves back; simulating the manoeuvres needed to to miss both an errant moose and oncoming traffic. Back in '97, pictures of Mercedes' newly-launched A-Class flipping over during moose testing led the German automaker to retrofit every single car sold with a new Electronic Stability Program module. And now those crazy bastards at
Teknikens Värld have put the Toyota Hilux through the same test — with similar results. (TTAC's American readers may remember the Hilux as the previous generation Toyota Tacoma pickup.) The video in the link brings back memories of the 1988 Consumer Reports exposé on the Suzuki "Somersault" Samurai. Anyway, hands-up anyone who thinks Toyota is going to retrofit ESP on old Hilux pickups? Yeah I thought so.
Surprise! Toyota Hilux Fails the Moose Test | The Truth About Cars
Motor Trader Malaysia Forum - Hilux Moose/Elk Test
No es oro todo lo que reluce: Land Rover Defender
Publicado por
Carlos en
Sucesos y
Land Rover.
El
Land Rover Defender, un todoterreno de los que ya no se hacen, el todoterreno
de pata negra, también tiene sus defectos.
Auto motor und sport, le puso recientemente las manos encima realizándole algunas pruebas típicas, como por ejemplo, la prueba del alce, y resulta, que en ésta última prueba, volcó.
Este hecho podríamos calificarlo de muy grave, ya que si bien todos los
SUVs que tan de moda hoy en día también corren un riesgo bastante más elevado que una berlina o compacto cualquiera de volcar en condiciones similares a las pruebas del alce, ninguno lo hace en la actualidad gracias entre otras cosas, a todos los sistemas de ayuda electrónica que llevan instalados. El Land Rover Defender, vuelca por ese motivo, ya que no cuenta con
ESP ni como opción, ni Land Rover tiene planeado ponerlo a disposición de los clientes aunque sea como opción. Está muy bien que Land Rover quiera que su Defender siga siendo un poco espartano para poder seguir siendo el mejor todoterreno para salir al campo, pero creo que es inadmisible que no traiga ESP aunque sea como opción sabiendo que con eso podría evitarse que vuelque en la prueba del alce.
Un problema similar tuvo
Mercedes allá por el año
97 con el
Clase A, el cual volcaba al hacer las pruebas del alce, y mercedes retrasó las entregas que tenía previstas para clientes para así realizar algunos cambios en las suspensiones para que no volcara en dicha prueba. Algo así por ejemplo no sería viable en el Defender, ya que entre otras cosas habría que rebajarle las suspensiones, y así se empeorarían sus habilidades camperas, por tanto, la mejor solución, repito, es ofrecer ESP aunque sea como opción.
Muy mal Land Rover,
muy mal.
Vía:
MotorFull
Más información:
Nissan Note:
Ratgeber Sicherheit - Schluss mit dem Schleuderkurs! - News - autobild.de
(post provisorio)
