Bom, creio que não há nenhum tópico sobre isto aqui no forum e eu como apreciqador de motas de água e barcos crio aqui este tópico para tal!
deixo aqui 3 videozinhos da sea doo 2009 com 255cv
http://www.youtube.com/watch?v=75sT39o7tBo&feature=related
http://www.youtube.com/watch?v=aN4xO6SjEt4&NR=1
http://www.youtube.com/watch?v=taFKWn3Xiso&feature=related
Specifications
Download Specsheet.pdf
Model Name: GTX Limited iS 255
Color: Topaz mist metallicMSRP: GTX Limited iS 255 starting at: $16,499
Dimensions
Length 139.2" (353.5 cm)
Width 48.19" (122.4 cm)
Height 50.3" (127.7 cm)
Weight(dry) 948 lbs (430 kg)
Rider Capacity 3
Fuel Capacity 18.6 gallons (70 liters)
Storage Capacity 16.4 gallons (62 liters)
Engine
Type 255 hp supercharged intercooled Rotax 4-TEC engine
Intake System Supercharged with intercooler
Bore x Stroke 100 mm X 63.4 mm
Displacement 1493.8 cc
Compression Ratio 8,4:1
Cooling Closed loop Fuel Type Minimum: 87 octane; recommended: 91 octane
Drive Unit Propulsion System
Sea-Doo Direct DriveRacing Pump with high performance intake grate axial flow single stage large hub Transmission Electronic: iBR, direct drive Impeller stainless steel Electrical Ignition digital inductive
Starter Electric
Battery12 V
LinkBack URL
About LinkBacks
Responder com citação
