Como vão as c-max`
Página 1 de 122 1211 ... ÚltimaÚltima
A mostrar resultados 1 para 30 de 3635
Título: Como vão as c-max`
    Por Defeito Como vão as c-max`
    Obrigado Chegalhavara
    Já agora, para saberem o que vao precisar na proxima revisao:
    http://www.etis.ford.com/fordservice...cheduleForm.do
    Deixo aqui tb todos os updates feitos pela Ford para reparar defeitos de fabrico:
    SSM 19168 EFFECTIVE DATE: 18/04/2006
    FOCUS AND C-MAX - INTERMITTENT ELECTRICAL CONCERNS
    SOME FOCUS AND C-MAX MAY EXHIBIT INTERMITTET ELECTRICAL CONCERNS, FOR EXAMPLE,
    WIPER PARKED IN MIDDLE POSITION; CLUSTER WARNING LIGHTS ON; RADIO INTERFERENCE OR ENGINE WON'T CRANK.
    BEFORE STARTING A DIAGNOSIS WITH WDS OR EXCHANGING ANY HARDWARE IT IS ESSENTIAL TO ENSURE
    SECURE B+ CONNECTIONS (3 OF): 1) NUT M6 (1-OF), FIXING OF B+ CLAMP TO BATTERY POLE: 5,4NM +/- 0.8. 2) NUT M8 (2-OF),
    FIXING OF B+ CABLES TO BATTERY CLAMP: 15NM +/- 2.3-.
    TSB 7/2006
    Subject/Concern: Hesitations; Poor or no start; Deteriorated fuel economy; Diagnostic trouble codes (DTC) P1412, P0490 and P1335 stored
    Model: Focus C-MAX 2003.75 (06/2003–) Build Date: 14.02.2004-01.03.2006
    Build Code: 4R-6S
    Assembly Plant: Saarlouis
    Engine: 2.0L Duratorq-TDCi (DW) Diesel
    Focus 2004.75 (07/2004–) Build Date: Up to 01.03.2006
    Build Code: Up to 6S
    Assembly Plant: Valencia
    Markets: All
    Section: 303-08
    Summary
    Should a customer express concern about one of the following:
    * hesitations,
    * poor or no start,
    * deteriorated fuel economy,
    and upon investigation diagnostic trouble codes (DTC) P1412, P0490 and P1335 are stored in the powertrain control module (PCM), the probable cause is a sticky exhaust gas recirculation (EGR) valve.
    To rectify this concern, a new EGR valve with a stronger EGR valve motor and revised PCM calibration should be installed.
    • NOTE: Use CD-42 or a later version.
    TSB 5/2006
    Subject/Concern: Inaccurate fuel gauge and inaccurate trip computer (if equipped)
    SSM 19013 EFFECTIVE DATE: 23/01/2006
    NEW FOCUS/C-MAX 2.0 TDCI - DTC P1412/P0490/P1335
    CONTINUING OF SSM 18859. DO NOT REPLACE THE EGR COOLER UNLESS THERE IS DIRECT EVIDENCE OF COOLER FAILURE, EVEN IF THE DEPOSITS ON THE EGR VALVE LEADS TO SUCH A CONCLUSION. A NEW DESIGNED EGR VALVE TO OVERCOME THIS LEVEL OF DEPOSITS WILL BE AVAILABLE SOON AND YOU'LL BE INFORMED WITH A SEPERATE OASIS MESSAGE. PLEASE BE ALSO REMINDED THAT THE USE OF BIO DIESEL FOR ALL FORD DIESEL ENGINES (MORE THAN 5% WHICH ARE BASICALLY PART OF DIESEL FUEL) IS NOT ALLOWED AND WILL INVALIDATE WARRANTY. IT CAN LEAD TO THIS KIND OF FAILURE ON THE EGR VALVE.
    SSM 18859 EFFECTIVE DATE: 03/10/2005
    SOME NEW FOCUS/C-MAX 2.0L TDCI MAY EXHIBIT POOR START; ROUGH IDLE OR LOSS OF POWER WITH DTC: P1412 (EGR FROZEN); P0490 (EGR CONTROL CIRCUIT HIGH) OR P1335 (EGR POSITION SENSOR MIN/MAX STOP PERFORMANCE) PRESENT. IF SO REPROGRAM THE PCM WITH THE APPROPRIATE NEW CALIBRATION AVAILABLE IN SERVICE FROM WDS CD B39A ONWARDS (REVISED PCM PART NO.: 3M51-12A650-AC; 3M51-12A650-NF; 3M51- 12A650-HS; 4M51-12A650-ZF; 5M51-12A650-MC) AND FOLLOWING ALL THE ON SCREEN INSTRUCTION INCLUDING RESETTING THE EGR VALVE. IF ANY CODES ARE STILL PRESENT AFTER ROAD TEST FOLLOW THE DIAGNOSTIC PROCEDURES FOR THAT CODE. SHOULD A REPLACEMENT EGR VALVE STILL BE REQUIRED THE NEW VALVE MUST STILL BE RESET TO THE PCM USING WDS. THIS FUNCTION IS FOUND IN TOOLBOX, POWERTRAIN, SERVICE FUNCTIONS, COMPONENT/PARAMETER RESET.
    SSM 5310
    FOCUS AND C-MAX 1.6 TDCI - LOSS OF POWER
    SOME NEW FOCUS OR C-MAX EQUIPPED WITH 1.6 TDCI BUILT BETWEEN JUNE 2003 AND JAN
    2005, MAY EXHIBIT THE FOLLOWING DRIVEABILITY ISSUES:
    1.MIL ON DTC P0404/P1412 (EGR) REDUCED POWER. 2. MIL ON DTC P0234 TURBO
    OVERBOOST REDUCED POWER. 3. MIL ON DTC P0238 TURBO BOOST SENSOR VOLTAGE UPPER
    LIMIT REDUCED POWER. 4. RUN DOWN ROUGHNESS. ALSO REDUCES OIL BACKFLOW IN AIR
    INTAKE SYSTEM IN COMBINATION WITH SSM 18120. 5. MIL ON DTC P0116 ECT REDUCED
    POWER.IN CASE OF THESE CONCERNS, A REVISED PCM CALIBRATION IS NEEDS TO BE
    INSTALLED. THIS NEW LEVEL CALIBRATION WILL BECOME AVAILABLE ON WDS CD B41.
    REVISED PCM NO: 3M51-12A650-MH; 4M51-12A650-NF;-KG
    TSB 40/2005
    * Loss of power,* Engine does not start,
    * Engine undershooting to a stop with immediate restarting possible,
    * "POWER STEERING FAILURE" displayed on the instrument cluster,
    Focus C-MAX 2003.75 (06/2003–) Build Date: 23.06.2003-03.01.2005
    Build Code: 3Y-5J
    Engine: 1.6L Duratorq-TDCi (DV) Diesel
    Transmission/Transaxle: CFT23
    Transmission/Transaxle: MTX-75
    one probable cause is a damaged wiring harness in the area of the manual/automatic transaxle
    TSB 11/2006
    Clock in Radio resets after engine crank
    Should a customer express concern that the displayed time and date in the audio unit or the instrument cluster reverts
    back to always the same values after engine start, the probable cause is a voltage drop during the cranking process of
    the engine. This could lead to a reset of the instrument cluster.
    To rectify this concern a voltage buffer module should be installed to the production wiring harness for the instrument cluster
    SSM 18579 EFFECTIVE DATE: 26/04/2005
    CLOCK IN RADIO LOOSES TIME
    SOME NEW FOCUS AND C-MAX VEHICLES MAY HAVE A RADIO UNIT WITH THE CLOCK DISPLAY RUNNING SLOW, A FEW SECONDS PER DAY COULD BE LOST.
    TO RECTIFY THIS UPDATE THE INSTRUMENT CLUSTER WITH REVISED SOFTWARE WHICH IS AVAILABLE WITH WDS CD37 ONWARDS.
    ID THE VEHICLE AS NORMAL; CHOOSE INSTRUMENT CLUSTER UNDER "BODY" IN THE GUIDED DIAGNOSTIC TAB MENU;
    SELECT CLOCK TIME FROM THE DIAGNOSTIC MENU AND PRESS THE BLUE TICK; FOLLOW THE ON SCREEN COMMANDS UNTIL THE PROCEDURE IS COMPLETE,
    THEN EXIT THE GUIDED DIAGNOSTIC.
    SSM 17927
    Desc: When the ignition is switched on, occasionally a Low Fuel Warning is shown.
    Fix: Updated Cluster firmware.
    SSM 7608
    Desc: When the ignition is switched on, a yellow warning with 'Limited EPB function!' is shown.
    Fix: Firmware update
    SSM 18122
    Desc: Noticeable flat spot in first gear around 1700rpm (TDCi engines) when pulling away from standstill.
    Fix: ECU Firmware update
    TSB 13/2005
    Desc: Leak from Turbocharger outlet pipe (1.6 TDCi) Oil pipe unseated during assembly.
    Fix: A revised turbocharger outlet pipe is installed Applies to models up-to 31/07/2004 Code 4D
    TSB 05/2005
    Desc: Light application of the brakes when reversing causes a loud squeel.
    Fix: Replacement Brake Pads. (Under Warranty)
    TSB 41/2004
    Desc: The time randomly changes on the radio clock.
    Fix: Updated Instrument Cluster firmware (current version 4.24 shown as ROM Level 0424 in TEST mode Later versions include the fixes)
    SSM 18356 EFFECTIVE DATE: 22/12/2004
    RADIO (SONY/5000/6000) INCORRECT CLOCK DISPLAY
    SOME NEW FOCUS AND C-MAX EQUIPPED WITH RADIO: 5000/6000/SONY MAY EXHIBIT THE RADIO DISPLAY SHOWING DIFFERENT CLOCK VALUES AFTER
    E.G. CRANK, DURING DRIVING. TO RECTIFY 1.DISCONNECT BATTERY FOR AT MINIMUM 5 SEC. TO INITIALIZE A CLUSTER RESET ( CLOCK DRIVER ).
    AFTERWARDS SET CLOCK AND DATE TO THE ACTUAL TIME. 2. ON C-MAX BUILT UNTIL 08.06.04 (4K) PLEASE WORK ACCORDING TO TSB 41/04.
    ALL VEHICLES BUILT AFTER HAVE ALREADY THE LATEST LEVEL SOFTWARE AND IT IS NOT RECOMMENDED TO REFLASH THESE VEHICLES AGAIN.
    IF THE ISSUE STILL OCCURS NO FURTHER REPAIR WILL IMPROVE THE SITUATION. THIS IS CURRENTLY UNDER INVESTIGATION.
    TSB 45/2004
    Desc: Ocassionally HID headlamp fails to ignite.
    Fix: Uprated Earthing Cable
    C-MAX POWER
    Bem pessoal vamos a mais 100......;)
    P.S- Vou tentar, ao longo do tempo, colocar aqui as fotos dos pópos do pessoal
    Ora bem, finalmente cá está a C-Max do kreisp presumo [8D]
    Consultor MGomes's Avatar
    Ribatejo
    [^] siga.
    Awesomeness!
    que venha mais 100 páginas como o outro...
    este eu vou acompanhar desde o principio;);)...
    LISBOA, , Portugal.
    parabens necos:D
    citação:Originalmente colocada por CANHOCA
    parabens necos:D
    Obrigado Canhoca
    O gajo que me ia fazer aquela cena no espelho....nunca mais se despacha....tenho que lhe apertar o papo
    Amanhã vou ao stand Moderno ver se está tudo bem com a EGR
    LISBOA, , Portugal.
    vais mas estas com algum problema nessa peça(egr)
    LISBOA, , Portugal.
    esse gajo e um tretas;)
    Eu não noto nada, mas também quando o computador disse que ela estava presa eu não notava nada, por isso sem ir ao computador não sei
    Não há problema pois ele assim, om este tempo todo que estou à espera, vai-me fazer aquilo por metade do preço;):D
    Piloto de Testes cmax's Avatar
    apá sóçe na terra do xokê frrite
    Bem... eu agora vou acabar por ser expulso... hehehehehe... ou oito ou oitenta... ando mesmo maluco com a nova actualização que só falo disto... e não é que à bucado reparei noutra coisa!! A terpidação das 1900RPM desapareceu ou então ficou imperceptível ;) e havia aí alguem que dizia que era um defeito que não tinha resolução
    citação:Originalmente colocada por necos
    Por mim pode ser quem quiser, ainda bem que o pessoal se interessa, por alguma razão somos o melhor tópico.
    Tive a fazer um apanhado do pessoal, se faltar alguém peço desculpa:
    Nice (aqui o meu cavalheirismo a falar alto)
    Dani c-max (irmão da Nice)
    Chegalhavara
    CarlosL
    Cmax
    Camadusa
    Kreisp
    necos
    Rafas
    Ricardo
    Tecedeiro
    Jcooper (já trocou mas continua na familia)
    Luis S.
    Jovil
    CarlosVaz75(já não tem mas pertence à familia)
    Francisco M.
    Imothep
    Joãocb
    LP
    machicosmina
    Se faltar alguém, que se chegue à frente s.f.f
    Amigo Necos... então e isto é para valer ou não?
    Por mim desde que não seja este fim de semana... a não ser que seja aqui perto... é que eu estou de prevenção até 2ªf
    Falta aí o Spike (Marco)
    citação:Originalmente colocada por cmax
    Epá!!!! Deram-te foi uma nova com a matrícula antiga:D:D..... folgo em ver-te contente, FINALMENTE, com a carinha....já merecias depois do que passaste[^]
    Chegalhavara
    CarlosL
    Cmax
    Camadusa
    Kreisp
    necos
    Rafas
    Ricardo
    Tecedeiro
    Luis S.
    Jovil
    Francisco M.
    Imothep
    Joãocb
    LP
    machicosmina
    Por mim é só combinarem.... até pode ser em Setubal;)
    Chegalhavara
    CarlosL
    Cmax
    Camadusa
    Kreisp
    necos
    Rafas
    Ricardo
    Tecedeiro
    Luis S.
    Jovil
    Francisco M.
    Imothep
    Joãocb
    LP
    machicosmina
    Quando fui ao ultimo passeio TT com o Discovery aqui na arrábida, o pessoal foi jantar ao restaurante "O Sobreiro" na lagoinha, entre a Auto-Europa e o Pinhal Novo... gostei daquilo, vou perguntar se estão abertos deste sábado a 8 dias, e em quanto fica uma almoçarada pro pessoal ;)
    quais são os sintomas?
    citação:Originalmente colocada por Ric_a_rdo
    Ricardo, nao tive sintomas, pelo menos que me apercebesse. Quando fui actualizar o software, a máquina faz sempre o diagnóstico, e deu álvula EGR presa.... o mecânico diz que com a repro aquilo deve ter ficado normalizado mas para passar lá que depois viamos se ficou bom. Como isto faz segunda que vem duas semanas, vou lá amanhã.
    Cá te esperamos para o convivio....não penses que te esquivas;)
    Chegalhavara e restante pessoal hoje à tarde vou pôr o W42, que chegou esta manhã
    P.S- Ai se o Bólide lê isto......:D:D[:I]
    Esperaí, isso é mais uma nova actualização?
    Necos... outra coisa. Sempre conseguis-te colocar o deflectos de vento junto ao para-brisas? Aqui à uns tempos disses-te que era só tirar uma peça e colocar outra... mas... tirar qual peça? Aquilo não se coloca por cima da existente?
    É... a W41...que é a que tu tens actualmente...já tinha alguns meses
    Setúbal, , .
    buuuuuaááá´,
    não me deixaram escrever na pág. 100 do tópico antigo!!.
    Opah, a carrinha tá tão boa que não sei se vou meter isso... olha... responde lá a minha outra pg sff
    essa actualização vai alterar que parametros?;)
    em relação ao almoço, vai ser muito dificil [8)]
    Piloto de Provas de Perícia JohnnyBlaster's Avatar
    Já não posso vêr tópicos a dizer C-Max á frente! :P
    Tou no gozo! Parabems ao tópico mais concorrido do forum (por alguma razão deve ser!).
    Antes mais deixa-me gritar W42 ALLEZ W42 ALLEZ W42 ALLEZ W42 ALLEZ ALLEZ[:X][:X][:X][:X][:X]
    A carrinha está um mimo....sabem aquela sensação que têm no carro, quando fizeram 500 Kms sempre a fundo na Autoestrada, em que ela fica tão soltinha que parece que ao minimo toca no acelerador...ela voa.....;) pois é essa a sensação que eu tenho na carrinha agora.
    C-Max e Chegalhavara, dou-vos um conselho... se estão contentes com essa repro...não mudem...porque aquilo tanto pode dar para o bem como para o mal....a mim deu-me para o bem[:X][:X]
    Ricardo vem lá pá[8D]
    citação:Originalmente colocada por Johnny Blaster
    tens que comprar uma C-Max[:I]
    Tenho, custou 50 + iva, salvo erro, aquilo é muito bom, pois diminui os barulhos aerodinâmicos.
    Não....aquilo é uma peça só, não se coloca por cima da outra. Aquela que vem, substitui a que temos actualmente e traz tb o deflector
    citação:Originalmente colocada por kreisp
    buuuuuaááá´,
    não foste a tempo:D
